Trucks been sitting
3,298
191
In my own world
Both have 2 us. The one on the timing cover on the 89 is way bigger than the 83. The fuel injected motors are different on the front.
You will be fine with the 4 piece gasket
Probably will be easier. Just use weather stripping cement to glue the cork to the block.
You put the rubber ends in first, then the cork.
3,298
191
In my own world
Sorry for the late response. Been the day from hell
No worries. When i get that one i think i ordered wrong ill know for sure which one fits. Hopefully the one piece wil wrk
Sent from my SM-N975U using Tapatalk
This cannot be right.......wrong one again.
. Does any one have a one piece gasket ?? Spent 40$ and not the right one
Never mind. I see how it works now. I thought there was supposed to be two smaller "u's". But I guess the front portion bolts in on the curve. Lol
3,298
191
In my own world
Front goes into timing cover
Was gonna do my oil pan today. But its raining crazy. Why does it take so long to do the oil pan? Labor time is super crazy. Im excited bout doing it. Guess itll have to wait til next weekend. Smh. Come on weather. I need a decent day
3,298
191
In my own world
Not so bad out of the truck, but a real pia under it, on your back reaching up, around, etc. Not to mention everything dripping and falling on you.
Rained all night and morning here, beautiful sunny afternoon but it's going to pour all night and day tomorrow
I looked under neath it last night before the rain. As soon as i got inside, it just started pouring. Hopefully it'll be ok this weekend. I really need to get it going
3,298
191
In my own world
I use weather strip cement the whole block. Keeps the gasket from slipping. Rtv or preferably gasket maker in the 4 corners, the gasket always leaks a tiny bit there.
Take a can of brake clean and papertowels and clean all mateing surfaces. Take your time
It doesn't look that bad except where the frame meets under the frame. What do u mean by the four corners? I have those wedges with that seal.
Ive never done an oil pan at all
3,298
191
In my own world
4 corners means where the round part hits the flat part. put a small dab of gasket maker or permetex right there in each corner, or spot
3,298
191
In my own world
Look back at my picture of the oil pan. You cN see where it squeezed out
Well after all that..... My rear main is actually the culprit. Smh. Ugg. Im definitely gonna have to take it in to work and use the lift now.... This is no good at all levels
