- 31
- 0
Hi guys. I have a few questions for you. First I am a hevy equipment mechanic. so most things will not have to be over explained. I have picked up 2 f-250's
One a 1990 xlt lariat 4x4 with a 7.3. the other is a 1987 xlt lariat 4x4 with a 6.9
I need to know what truck had the better frame if there is any differences. what truck had the best trans or are they the same. what diffs. I plan on a ground up resto. I ABSOLUTELY GET SICK when I see these new trucks that cant haul a bag of feathers. have ridiculous emission crap, and just all around suck. Old iron all the way.
Also Should a use the 7.3 or the 6.9. what components are interchangeable.
Both trucks drive. Although the 6.9 has a bad injector and the 7.3 was driven home without cooland. The guy hit a deer punctured the rad. I got it for cheap, figured do a blow by test if the rings are good, plane the heads and go with it.
any help would be greatly appreciated
