1985 Ford F-150
Country Boys Can Survive
Is it leakin oil anywhere around where its smokin? Or did ya put a plugwire too close too the manifolds?
OMG it's gonna blow up!! Run!!!!!
LOL it is highly possible that it is just stuff burning off since you had it all apart. If it is getting better. It should be ok if you have no fluids leaking anywhere. Just keep an eye on it. I think you should be ok. I've had the same type of stuff happen. Just check for leaks or anything that can cause the smoke, but if it is getting better it is most likely stuff burning off.
) and there was no more smoke, but the smell was still there.Maybe ya spilled somethin when ya put it back together and it just stayed pooled in there till it got hot?
Couldn't you just make it yourself?
Is this somehting that came factory?
oops my bad... was thinking different rattleYeah...it's the 'felt' that runs around the window frame to prevent it from rattling.
Ben, I don;t want to overstate the obvious, but have you tried replacing the striker bolt? Or is it rattling more inside the door? even IF the plastic sleeve on the bolt is still there, they get reduced in size by wear.
Could you just pull it off a junker?
Turn the radio up or get a louder exhaust![]()
Where are you guys getting you door anti-rattler kits from? I just find it rough spending $200+ for some felt and rubber. But if that's the going rate, I guess that's what it is.
