Trouble shooting 4WD from the warmth of my living room.
Oh sorry...I misread.
The slip joint will need to be cut off and a new one welded on...that then requires it to be balanced...or should anyway :D
The slip joint just slides off......? it fits on a 19 spline shaft, or am I missing something?
Usually both halves have worn...so replacing just one side kind of defeats the purpose.
That was my thought also. I want to replace with new, but am coming up empty on my particular application. :(
416
The splines get worn after while, then you get the rocking you are observing. It depends how much and how fast you would ever run the 4wd as to how much it matters. I have slop on my 86 and 88, but since I don't run 4wd down the highway, it really isn't that big an issue. At slower speeds, the little bit of wobble you might see isn't a big problem.
Sparky83
Virginia Chapter member
5,571
226
Norlina NC
416
The splines on the driveshaft are a welded part, so best left to a driveline shop who has the parts and equipment... Local shop can do it in the $100-$200 range.
Sparky83
5,571
226
Norlina NC
that they do..
sometimes repacking the joints with grease will take up the space.. so long as its not twisting between the joints i wouldnt worry about a minor bit of play in the joint.. and what i mean by minor is fraction of a fraction of an inch... if it to the point your able to flex it quite a bit that would be the point id start to worry...
I actually remembered to check them out this time. I am NOT seeing a front driveshaft for a NP 205 that does NOT have a CV on the driveshaft with PT 4WD.
So......the next question is, could I use a CV joint on a front driveshaft that was originally designed for one. I might call the good people at Quad 4X4
tomorrow.
Sparky83
5,571
226
Norlina NC
its only the one side they have there anyways..
Sparky83
5,571
226
Norlina NC
tomorrow.
couldnt tell you mate... i just looked up the 78 f150 front shaft... theyd for sure be able to tell you better than we could for sure..
I'm confused here. Doesn't the slip joint just slide off the end of the driveshaft, or are you saying the wear is actually on the spline on the end of the driveshaft?
416
Trick is, what is a little, and what is a lot? :0
Our old farm trucks have some play, and get a little wobble if we were to dare run them at highway speeds. I have run down the road with the front locked in but not 4wd when the roads are bad and notice only a small vibration. It does take quite a bit of wobble to become a functional issue.
Come to think of it, the 205 is a full time case, isn't it? That is a little less accepting of letting it wobble in that it will be more noticeable when running at cruise speeds.
416
It is on both parts, the splines that are on the yoke to the axle, and the splines on the driveshaft end.
416
I can never remember which is which...
Sparky83
5,571
226
Norlina NC
slip joints are 2 parts... both have interlocking splines (im sure you already know this part).. and both wear out together equally usually... sometimes though one side will wear out more than the other but its rare case that happens.
exactly... and everyones definition is different from each other..
It boils down to: I want to replace the whole front drive shaft, but can't find one for my application. I've located one on bronco graveyard, but am unsure of the quality.
Sparky83
5,571
226
Norlina NC
driveshaft shop could most likely custom fab you one im sure..
