I am starting to get a noise from underneath the truck when the truck is put in 4WD. It almost sounds like a fan blade rubbing on a shroud and is speed affected to a certain point.
Here are the symptoms: '78 Ford F-150 NP205 Transfer case(Part Time)
Hubs out: no noise
Hubs in: no noise
Hubs in, 4WD engaged: noise up to about 20 mph, then ceases. Noise interval increases with speed up to about 20 mph.
Here is my understanding of what goes on when hubs are in or out:
Engaging the hubs connects the axle shafts to the differential.(Axle shafts turn) Does the front driveline also turn when just the hubs are engaged, or does engaging the 4WD allow the driveline to connect to the transfer case?
I'm thinking the noise is in the U joints of the front driveline. There is a little play in those U joints. I already have the U joints, but am waiting for warmer weather to replace.
Hubs out: no noise
Hubs in: no noise
