- Moderator
- #21
Pretty much the black I saw looked more like grease, not staining, but it really doesn't matter.
The only way a decent weld could be done is if it was bolted to a block, and they have to gouge the break such that they can get full penetration. Otherwise it will most likely not stay in proper position, and will also be weaker than the original by far. The things I would be concerned with beyond the broken bell is that there may have been some internal damage, as the only way bells break like that are when the converter isn't seated properly or something wasn't, ans they tried pulling it up to the block with it not all in proper placement. As Charlie suggested, swapping it from your case to another case would find any of those issues, if they don't just try to sneak it through. At this point, it doesn't seam they are too concerned about making it right, just getting you gone.
On the oil foaming, think about how something like milk foams up when you run a beater through it. The beater in the case of the oil would be the crankshaft, as it dips into the oil level and whips it up. If you are overfilled enough, this is what actually happens. There is a valve in the oil pump that keeps it from over pressurizing the system. It of course can not control low oil pressure, only higher pressure.
Take that, overfilled oil guy.... (I may be shooting myself in the foot here...)
