Ridgerunner
I had my son put a new fuel pressure regulator on my truck today and after getting up to operating temp it still stumbles,almost shuts off. It's driving me crazy, time to burn it.
I had my son put a new fuel pressure regulator on my truck today and after getting up to operating temp it still stumbles,almost shuts off. It's driving me crazy, time to burn it.![]()
trying to find the issue. Timing may be something to check, fuel pressure, vacuum leak??Whoa Nelly!!!!!!!!!
lets talk about this Cliff. So if I'm getting the right picture, your truck was stumbling before? You have EFI if I remember, soooo, you need to get a code reader. I had EFI in my BroncoII, and since there are sensors involved, it's the only way to trouble shoot. I had a fuel related problem with it and it turned out that the fuel rail and pressure regulator were at fault. The EFI's also have two fuel pumps, one high pressure and one low pressure. Electrical can come into play too, so you see the picture, you can go in circlestrying to find the issue. Timing may be something to check, fuel pressure, vacuum leak??
need more details to get to the bottom of the rough running, but sounds like it's fuel related.
It is fuel related. The fuel pressure regulator was full of gas and had to be replaced. I also replaced the fuel pump relay. My truck has 3 fuel pumps (2 low pressure and 1 High pressure pump) Those will be last resort.
My truck runs great when cold and up to operating temperature when it hits the o in normal on the temp gauge it will surge,buck, and try to die. I and my son are thinking it's the fuel injectors so a rebuild is in the works for those and I can clean the fuel rails while it is apart. Bad part is I don't know how to pull codes or where to pull them from,plus the check engine light? hasn't come on.
I see. (Getting my head back into the Ford Electronics) If it was the fuel injectors, you would experience problems at all temperatures. Before you spend money on a rebuild, try injector cleaner. Out of the blue, I remember having a ground issue that caused all sorts of problems.
I can't remember which is which (open cycle or closed cycle) but it sounds like when your truck is done warming up and starts relying on the sensors, it is either running rich or lean. The warm up cycle tells me that there's nothing wrong with your injectors.
I have ran a can of Seafoam with a full tank of gas, also replaced the fuel filter. We did a full tune up new plugs (NGK), plug wires, rotor button, dist cap.
The local parts here only use readers for OBD II and up. I will have to buy a reader. Which to me will be well worth it.
Yeah Cliff, I paid $20 for mine a few years ago. I was in a parts store recently and saw it on the shelf for $29.99. It's WELL worth the money. Mine was a yellow reader that even came with a diagnostics book that would give you a more in depth explanation of the code. With electric controlled vehicles you can't get by without a code reader.
I think you are thinking of the O2 sensor Ryan. It is warmed by the exhaust though, and typically is warmed up in about 5 minutes. However, a temperature switch that controls some vacuum function would cause trouble like that if either making a vacuum leak or something downstream is disconnected.
