Started on the Interior
Can't wait to see it all.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
PICHERS!!!!!!!!!!!!!!!!!!!!!! or else! LOL
Ridgerunner
573
Stillwater Ok
Here is my score from yesterday and today.
Today these wheel I got at a yard sale today for $75.00
X4
I haven't seen that design before. They look unique. I think I like them. If I lived a little closer to Tulsa and you left your garage unlocked.........
Ridgerunner
573
Stillwater Ok
I also picked up this storage cabinet and lights for my garage.
I got 4 of these lights
Ridgerunner
573
Stillwater Ok
LMAO But I don't leave it unlocked.
But I am trying to figure out the lug nuts I need, the po said I needed extended lug nuts?
Ridgerunner
573
Stillwater Ok
Awesome Cliff, now to put it all on your truck. Yes, by looking at the pic of the rims you'll need the longer lug nuts, nothing out of the ordinary. You can get them at any parts store :) Don't forget to polish everything!!
Any idea of the style of lug nuts?
416
Cliff, measure the hole size, as well as the hole depth. There is 2 shoulder lengths on the mag nuts. If you get ones with too l0ng of a shoulder, the rim will stay loose, and then wobble, which will lead to big trouble. You need the shoulder to be about the depth of the rim thickness. if there is a taper on the rim like a regular lug would go into it, then you just need a wide base tapered nut, the hole size should be about the same as the lug diameter if that is the case. The shoulder style uses a flat washer behind it, while the tapered base does not.
Ridgerunner
573
Stillwater Ok
I better go to the tire store.
416
A "Good" parts person will know what you need... If a tire shop deals in aftermarket wheels, they should hopefully have a clue.
Ridgerunner
573
Stillwater Ok
There are a lot of shops here that sells aftermarket wheels. These seem to be made in the 80's and I still don;t know the name of them.
416
Most times they cast their name on the inside of the rim, otherwise you will find it when they take the tire off. Should be by the valve stem with the tire off. they look familiar, just cant come up with who for sure made them. Thinking either Cragar or American Racing.
