New Derale Trans Pan is On!
TheRoadVirus
High-Steppin' Mo-Sheen
2,461
31
Ontario, Canada
All you need to do is fix up that front bumper and she'd be poi-fect. Or am I just imagining things.
I want a garage like that. :(
663
No my front bumper IS crooked. I always thought that the brackets were bent after I rear ended someone but a guy on the "other site" recently said that the bolts can slide forward and back to allow for adjustment, so I'm going to look into that today.
Brian_B
blank
Set a jack under the back edge (part that is down), loosen bolts slightly (on that side), jack the bumper up into place, tighten bolts. Repeat for the other side.
Almost that easy. Would be easier if you had an extra set of hands, but I have done it by myself before.
Brian_B
blank
If the plastic trim is made like ranger...you can just slide the plastic trim out of the slots on the end and go for it. :)
EDIT: I usually use a small floor jack for this. I have two small ones and one large one. A bottle jack or the ford truck screw jacks would work too.
just take it off and see what you have to work with. If there's bent stuff, you may need new mounts. No tellin, really. With your california climate, I'm going to bet your bolts aren't rust welded on like mine were.
Lost
PA Chapter leader
3,288
central PA
If horns r bent U can put large fender washers behind mount if the jack does not work . Sometimes the accordion part of frame gets compressed so its washers or pull it out carefully.
663
Hey that's a great idea! I think I might try that this weekend!
