need underhood wiring diagram for 96 F150 5.0
2002blgt
dirtydirtyracing.com
anybody got a good schematic on the injectors , MAF , TPS , IAC , O2 sensors etc , I have the pinout schematic for the ECM , doing a OBD2 conversion on a 95 GT
msb71
Virginia Chapter Leader
1,624
28
Hampton,VA
Where is Subford when you need him , he'll be around soon to get ya what you need.
Mike
651
I've got some of these but they're all in separate diagrams... I'll be subford's got a bigass one that'll show it all :)
2002blgt
Thanks that helps , now which O2s are the front 2 ? they are numbered 11-12-21 from what I can tell , you got a detailed wiring of where they go and exactly what pin of the ECM goes where for those ?
11 is bank 1 sensor 1........12 is bank 1 sensor 2. Sensor 2 is downstream.
2002blgt
Ok here is another question , I just went and looked at my uncles 96 f150 5.8L , it has a crank sensor and a distributor , anybody got a clue as to what wires go to what pins in the ECM , the ecm pinout subford got me only shows the PIP , Ignition ground , etc which I wired to the cars wiring , which only has a distributor , and what is the misfire sensor and does it have to be wired up ? is the misfire sensor the crank sensor , the reluctor behind the harmonic balancer only looked to have one peg sticking out ?
You asked for a pin out of a 96 5.0, the 5.8 is different.
Do you want a pin out of the 96 5.8 also?
If so is it over or under 8500 GVW?
Misfire Sensor, 1996 5.0L Center front of engine, on timing chain cover.
2002blgt
I just looked at his because it was same year , the ECM and harness I have are for a 5.0 manual tranny , its going in a 95GT mustang 5spd , well from the location of what you described that is the only sensor on the timing cover I can see
2002blgt
send me the one for the 5.8 just incase so I can use it for comparison if anything else .......I need to know of the misfire sensor has to be hooked up for the engine to actually run , I might get my uncle to come up to my garage today just so I can unhook it and see if it will run without it plugged up ....
2002blgt
Just found out the sensor on the crank is the misfire sensor , went to my uncles house and unplugged it and the truck runs fine without it hooked up , has no affect on the ignition itself ....
