Alright fellas...finally got the Bronco all buttoned up and put back together. But hot damn, something on the driver's side of the engine is causing an asston of noise and given a little throttle the damn thing dies...and was difficult as all get out to idle so I could get a timing light on her. Looked to be right about 15* though before she died. I let her run 3 times for maybe 5 seconds each time, then threw my hands in the air and quit for the night. FWIW...in the last month, it received all new gaskets and seals and timing chain set and now in the last week, it got all new gaskets again, but while the oil pan was off, I took a thorough look and everything looked perfectly fine and no metal or anything in the pan. And I put 'new' reman'd Motorcraft distributor in it tonight.
My thoughts are, the old distributor was bad bad bad, after comparing it with the new one, it would catch and grab and almost felt bent...so I'm going to say that caused the timing issue. Then as a result of the timing issue, I lost a couple pushrods on the drivers side and that's what's causing the noise. Does this sound logicalimous to anybody? The pushrods were fine on the PS side, but I didn't think to remove the DS to check the pushrods.
Anyway...as always, thoughts/ideas/advice/insight is much appreciated. Oh, and the engine is a 78 400 in a 79 Bronco.
