And things just keep adding up.....
384
omg..... this is really frustrating me..... just went outside with a flashlight to see if i could confirm where the oil leak is coming from.....
well i did that and something else.......
has to do with the coolant leak i have......
I'll let yall just guess.....
as if my day couldnt get anyworse....
Water pump? :suspicious:
Oh damn, tell me it's not a head gasket? :suspicious:
384
I wanted to see what everyone else was thinking before i let yall know....
but yeah Ken, its the Head gasket... drivers side rear.....
good news is.... its not leaking into the oil.... just leaking to the outside of the block...
That's usually how it goes man. Sorry to hear it, but it's almost a 20 year old truck, with a couple hundred thousand miles on it, it's to be expected.
Ben, mine's 34 years old.....should I be looking at another engine? smilietease
Don't mean to joke here and bust your balls.....hope it works out.
'balls'
If it's any consolation Chris, that's kinda what happened with my 79. Before I parked it for winter the first year, I had to adjust the antifreeze concentration and as soon as I touched the rad, it started to leak..then come spring after it had sat all winter, rear main, valve cover, oil pan, rear end, transmission all started leaking. I feel your pain...it just sucks when it happens all at once, esp given that it is your daily driver.
1985 Ford F-150
Country Boys Can Survive
7,816
307
Tooele, Utah
Ive come to expect it now after the 76. If somethins been sittin a wjile and all of a sudden it gets driven ever day its gonna leak most likely the pinion seal then the transfer case etc etc.
It isn't that hard of a job to get done over the weekend as long as the heads are not warped.
polarbear
just growing older not up
12,878
607
Boring, Oregon
I'm gonna loop back around to that $129/mo KIA lease special. You guys need to have at least one reliable, bulletproof, warrantied vehicle in the driveway. Serious.
Should be fine. Just get a complete gasket set and get to work :)
