Thanks for the advice Larry! I plan on swapping my electric tcase over to the ZF. Also -- you say the pedals are the same --- you mean the pedals out of a gen 8 and EXACTLY the same as the gen 9? Still haven't figured out which may I'm gonna go with the ECU thing -- I'll cross that bridge when it comes.I Work a week of 16 hour days look at all the posts I missed.
Everything should be a go . U got the front shaft covered as said . floor pan,trans ,exfer case, And know a good shaft shop. Peddles r same
Only thing I see is your xsfer is electric . You need manual exsfer (Probably know it ) And shift linkage ,boot for inside.
Cosmetically u will need the manual plate ,(To delete indicator ) gauge cluster surround,and the covers for steering colomn to do away with hole for Zf.
If u can't find a ECU (and this has probably been descussed and I missed it ) I'm told thet if u wire MPLS sensor to be in neutral (Loop ) It will work fine with Manual trans.
I admit I skipped threw this post a little so sorry for rehashing things already descussed.
