Big Bronco Discussion
Question guys...I will potentially be picking a 10.25 out of a 90 350. Will this axle have a VSS and would it even matter if it went into my Bronco? The speed input will be coming from the same spot for the Bronco...then if it does have a VSS, is there anything I should do with it...or just let it blow in the wind?
Truckin4life
Texas Chapter Leader
Correct it has the vss in the axle.
Its actually just a sensor no problems if you dont plug anything into it, maybe make a cover so if someday you decide to use it you can pull the cover and be good to go.
Alright thanks Don...just needed someone to help sift through my thoughts with me. I'm pretty much a rookie when it comes to axle tech, but I'm trying to change that.
Truckin4life
Meh so am i, but i read stuff a few times, then when somebody asks a question i try and remember it. Sometimes i have to go back and refresh.
I know your answer as i have a sterling... So it works.
Well once again...thanks.
Truckin4life
Yes sir.. Not a problem, i have no issues sharing my knowledge with others, since that is how i got my knowledge to begin with. That and learning from experience.
The trip is pretty much on, minus the Bronco (I think). Apparently it isn't used to being driven like that and will break down:blah:.
LEB Paul
I like Broncos
Are you finally growing a pair and going to tons? :cool:
