Anyone have any trac bar pics I can use as a comparison to mine? If ya do, post it here, PM me, or email me...thanks.
Anyone here done the F350 brake upgrade?????? I plan on doing it when I get home...I only plan on doing it when I get home...I'm only planning on doing the MC/booster for the time being, and I'll do tbird calipers and 350 cylinders at a later date. Anyway, am I correct in the assumption that the only thing that isn't a bolt in is the fitting to the front brake needs to be swapped to a 3/8 threaded nut...and the brake lines need to be re-routed????
This is just a general big Bronco chat thread, right?
Here's a question- what would my odds be of finding a nice (read: very little rust, not beat, not crazy-high miles), '87-'96 Bronco with a 5-speed and a 302? And what might it cost me?
I'm expecting to have to travel a bit to find a rust-free one, and not shopping until next summer at the earliest, but I've always liked those trucks.
Also- what might I expect to get for gas mileage from that combo?
Here's a write up on the change. Someone posted this awhile ago and I saved it incase I needed to do it
http://www.okcnetworks.com/bronco/brakes/index.htm
Yes, make sure you get the right year! If you have a '79 I have the mc/booster sitting in my shed (I bought it for a 79 and I have a 78 DOH), but it has been sitting out there for a while not sure if they can go bad from sitting or not. Other than that it's just redoing the double flare for the right sized lines. I didn't do the tbird stuff because I put 1 ton axles under it anyway, so I have F350 brakes all the way through.
Hell I don't even remember what I paid for, maybe been sitting a year, two years tops. Hows 100 plus shipping sound??
hey make me an offer, it's just taking up space
Thinking about a driver, not a project....I'd really, really like to get into something reliable and 4wd before I start blowing any money on toys. And at this point, it's one or the other...cash only goes so far.Get a 351w and swap in a zf5 Ian
If it's not a stick, it negates the rest. No interest in an automatic whatsoever.If you're willing to travel, rust free will be easy, finding a 302 will be easy, under 4k will be easy...finding a stick will be pretty difficult IMO...I haven't seen too many at all.
I said 302 mostly because I was thinking it would be the easiest to find with a stick, and also thinking a bit about fuel mileage. I dunno much about how Broncos were optioned, it just seems that around here, virtually none of the F-150s of those generations with the 351 have the manual trans.However, it's been my experience that the 302 isn't enough engine for these things, especially with high gearing...so you're constantly on it...and typically, the 351W and the 302 get about the same mpgs...seems to be the general concensus on FSB too. So why not go with the 351W for a little more power...and it seems there are a few more 351's with a stick. Another tidbit, stay as far away from the AOD as posible, so that leaves the E4OD...and as we know, until 94 the E4OD had some gremlins...so if I were you, I'd search for a 94-96 (96 has MAF) with a 351W and stick.
Hey Ian...not at all what you said you wanted...but there's an 85 Bronco 300/4sp you could probably get for 1500 on FSB right now. It looks pretty nice. I just saw it, and instantly thought of you. However, it's in Georgia...dunno if you'd wanna make that trip...although, it would only be about $100 bus ticket and probably a 22 hour ride
