whats the best way to put valve covers on
hey i have new valve covers and im wondering whats the best way to put my valve covers on so ik they wont leak any post will help thank you
nobodyspecial
Fire in the hole...
5,756
366
ND
I recommend gaskets... and bolts... Gaskets and bolts should work.
7,086
459
upst ny
While I agree with a couple above....I've always done RTV on the bottom of the gasket, the head side.....Never had a leak! I use the blue RTV and in all the time I've used it...tougher than woodpecker lips and easy to get off in a maintenance situation...putty knife.
Alternate corners on the fasteners. From corner to corner working to the middle of the valve cover.
My suggestion.
I bet I've put on 50 sets of V-covers...never a leak.
smokey
Hitech hillbilly
I tie the gaskets to the valve covers with thread. That way they don't shift and not line up. start your bolts and pull the thread out and all is good. I like the felpro silicone gaskets the blue ones.
haha thx guys yea i got the gaskits i was wondering if i should use any sealer with the gaskits iv herd alot about like JTV wondered if its any good
flareside_thunder
7,812
246
are they cork or rubber?and yea that's the way I've done it....I usually do both sides...put some on one side and stick it on the valve cover then let it tack up a bit then stick some rtv on the side as well, the side that faces the head.
2,285
193
Los Angeles
iv herd to put rtv on the top side of the gaskit and stick it to the v covers and then put them on like that
That's what I've always done. A small even bead of permatex on the valve cover, plop the gasket on, let it set up a bit and bolt it down.
UNRULEE
^LARGE carbon footprint^
5,412
424
Coal Country, ND
Last time that I put v/c covers on I used rubber gaskets and had a horrible time getting them to stay in place. I finally took 10ga wire and used single strands of wire to tie the floppy rubber gaskets to the covers. They worked great after that.
I tend to use either silicone or weatherstrip adhesive to keep them in place. Be sure the holes aren't bowed out either, take a ball peen hammer to the holes and dish them backwards a bit so that when you tighten the bolts, it pulls the metal back down.
I haven't tried the Felpro Permaseal (blue silicone) gaskets yet, but have been strongly considering them...
TexasNomad
FTFS Designated DRINKER!
I like using that Tack stuff thats sold at the auto parts stores, it holds every thing in place and also makes them seal up better :)
