whats the best way to put valve covers on
1985 Ford F-150
Country Boys Can Survive
7,816
307
Tooele, Utah
I use some stuff called great stuff its black and it is the absolute best sealant ive ever used. I put it on the valve cover then put the gasket on and then another layer of sealant. It comes in either a regular caulking gun size tube or a mini size one. I also spread it out with a popsicle stick so it dont squeeze out.
i use rubber gaskets and no sealer. what i found helps with the floppy rubber gaskets, is to stick the bolts through the valve cover and the gasket that way they hold everything in place, this usually works because the bolt is usually ever so slightly larger than the hole.
bigun72
XLT= Xtra Loud Truck
306
8
Jackson,TN
when i rebuilt my motor i used rubber gaskets.....they suck
UNRULEE
^LARGE carbon footprint^
5,412
424
Coal Country, ND
I tried 4 studs (chopped off longer bolts) on each cover and they still wouldn't stay in place. That's when the swearing and finally the wire came out! I remember reading about it in Four Wheeler some years back, it works!!!
I'm old school.
I use cork gaskets soaked in warm water for an hour, then apply coppercoat to the valve cover side of the gasket and a little on the valve cover itself...once they are tacky I place the gasket on the valve cover..then apply it to the head..being careful not to tighten too much.
i never use sealer on rubber unless a damaged the gasket and need to drive to the parts house for new ones. i always use sealer on cork, it makes it possible to remove the cork gaskets without a scraper.
