What size tires??
Lost
PA Chapter leader
3,288
central PA
Welcome.
They fit . I hate the packed wheel well look . And if u go off road at all things have been known to get bent . Like lower fender ,bumper, I have run 32"s
AS for the rims . i ran 15x10 with the 31 10's for years . Might not be right but worked. Even 31's will run rad arm
msb71
Virginia Chapter Leader
1,624
28
Hampton,VA
I am currently running 32X 11.50X 15's on mine < i had to trim the bumper, it was rubbing when I had it in reverse and full lock.
fords4life91
"The best NEVER rest"
Welcome.
WOW thats crazy every tire manufacture says that in order to mount there tire on a 10 inch wide rim the tire has to be at least 12.50 inches wide??
So what do you guys think 31x12.50 tire would look like?? Would it even fit??
Thanks, Justin
Mr. Stroker
CASE IH
3,121
67
Michigan
They fit. ppl put 35's on our stock wheels. Wear might be a little off.
polarbear
just growing older not up
12,878
607
Boring, Oregon
I don't even think I've seen awampers that size. 12.5's usually go along with 33's. then you get to ask questions like "how much does a remanufactured power steering pump cost?":headbang: Nick's just blew out in his Ranger- service manager said it's a common issue with oversize tires. To be fair, same thing on Chebbie- our shop does a couple a week.
fords4life91
Pro-comp has 31x12.50 tires!!
