Castrol GTX 10w30
Brings up a question though...I remember my granfather (who was a Ford Master mechanic) telling me all the time that the 3000 mile mark was a marketing thing to keep business coming in. He said the guys at his shop and dealership would laugh at the folks that needed routine 3k changes. He said he'd never think twice about letting oils last until 10-12k or a year...
It's the additives that count. I think we can all agree that using the "bare minimum" is obviously not as good as using a highly refined, developed, and chemically improved oil, right?
Ben said:Won't that depend on what kinda fan you have???????????? HAHAHAHAHAHA, just playin. But yes, I agree.
what he saidCastrol GTX 10w30
Re: Royal Purple....I do it in everything BUT the engine, just b/c of price. I feel good spending a little extra money for something i'll likely never touch again (axles, t-case, etc)Geezus...how do you guys afford that stuff...I can't even afford to THINK about going RP for even an oil change, much less the whole truck.
Here are these benchmarks, they are pretty interesting: http://www.smartsynthetics.com/articles/api_comparative_motor_oil_testing.htm
Castrol GTX did really good on the high temperature test but crappy on the oxidization one, synthetic did seem to help though.![]()
Try having a motor blow at 33000 miles and trying to get it covered under warranty. See if the 3-5000k mark is still laughable.
There is no doubt in my mind the oil CAN go longer but how many oil changes can you do for the cost of a $3000 engine?
Good post. But they never make the claim that all oils are created equal. They only claimed that store-brand oils can actually be of the same quality of the higher-grade (ie, higher-priced) oils. Which in my experience is true. If you read the Boss 302 article I posted earlier, he touts WalMarts SuperTech oil as being a very good oil.Blackstone Laboratories, a well known respected independent tester of oils has this to say.
LINK:
Managers and analysts at Blackstone Laboratories often do presentations regarding the fascinating world of oil analysis. Regardless of the immediate topic, the most common question we hear is, "What type of oil should I use in my car?"
Because we're an independent laboratory, we don't recommend any specific oil brands. We always recommend using an oil grade recommended for your engine by the manufacturer and a brand that fits your budget.
You can go into any mass retailer (Wal-Mart, K-Mart, Meijer, etc.) that sells engine oil and buy a 10W/30 (or any other preferred grade) that will perform well in your engine. One of the best-kept secrets of the oil industry is that these store brands are actually the same, quality oils that are produced by the major oil companies. The only difference between these products and the major company brands is the name on the container and about 50¢ a quart.
But wait! We do actually have a preference when it comes to buying oils for our personal use engines. That preference however, has little to do with brand names.
We analyze oils from our personal use engines (right down to our lawn mowers) religiously. We tend to choose oils that do not contain additives such as sodium and copper. The copper additive masks brass or bronze wear from the engine. Sodium additives can mask anti-freeze contamination.
There are many types of after-market additives you can buy. Some contain unusual compounds that can make it difficult for our analysts who are trying to determine if your engine has a mechanical problem. One additive we know of contains a lead compound. But lead is a metal common to bearing inserts. If you're using an additive with lead in it, it is difficult to tell whether the high lead is from your additive or a problem with the bearings.
Another type of additive we often run across contains silicone (which is read as silicon by our spectrometer). Silicon is often found in the oil when a fault exists at air filtration. If we do not know there is an additive in use, it can be difficult to diagnose true problems that may be producing high silicon.
If you are interested in having your engine oil analyzed by a quality lab, you will receive a better analysis if you avoid oils and after-market additives that use elements we need to see clearly to do a thorough analysis. If you feel you truly want to use an after-market additive, please let us know about it on the information slip provided with the sample.
Boss 302 said:The oil that Wal-Mart sells under their house name (Super-Tech) is very good quality oil. In many tests done over the last year or so, the 'Super-Tech' oil was superior to many name-brand oils.
Ben I'm not arguing against you. I believe that oil can and will go longer in a vehicle BUT having just been through what I just went through with my engine...On a vehicle STILL under warranty, it will be the recommended schedule for me
