1985 Ford F-150
Country Boys Can Survive
Sounds like its the later style. If its a 72 like ya think it is it might have the v6 like mine does. How much did ya pay for it?
As long as it runs, it should be one helluva beater...if it doesn't run, get it right before investing in cosmetics.
Cough 5.0 cough
hey now! remeber i get my license soon and they should let me go down there not tooo long afterso i could help some
I told you, you can help work on anything I own, but don't expect to get paid.![]()
silly!![]()
:thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay::thatwasgay:
gotta get my license first silly!![]()
:thatwasgay:AGREED!
how did i know that was gonna happen....
Because, you said what you said... it's about as manly as wearing tight pants, pink tanktop, hair pulled up, while ridding in a pink convertible PT cruiser. rockin' out to N'sync
u know me well enough to know i wouldnt do that![]()
If I recall right itll be a 258 with a 1bbl carter carb. Make sure ya flush out any old fuel thats in it and go through the carb, also changin the oil, plugs wires, cap and rotor would be good for it. Is it a stick or auto?
Did you ever get the chebby to start?
Just try cleaning the points first. Hit them with a point file, or a nail file then re gap them.
On the Lumina's and similar chassis, the top "dogbone" mounts come loose with one bolt, then you can tip the motor forward, pin the motor forward using the provided spot on the bottom side of the dogbone, and there is plenty of room to get at the plugs and such on the back of the motor. My old man's Regal has a power steering line leak, the pipe actually rusted through. It is beyond a beater though, so it for the most part has been retired.
Something to watch out for on the Luminas is the rear struts. They tend to seize up when they fail, making a heck of a rough ride. They are easy to replace, but you need to do it before they rip the upper mounts out. Coil packs can be a regular problem as well, not a lot of fun to get to. Otherwise, they are pretty decent cars. My wife's Grand Prix had 227,000 miles on it when she rolled it, and all I did to it was head gaskets, middle coil, and rear struts besides the normal maintenance stuff. Took that motor and put it in the Regal, and it still is going in there, and that car had over 200,000 miles on it, but the odometer quit working (typical for the Regals) but the car went on for at least another 3 years. The first motor went out courtesy of my sister, who does a good job destroying motors by not checking things or doing oil changes. It had a spun bearing...
