I haul a fairly heavy camper @7000 pounds with my '06 F350 V10. While I have generally used the Tow/Haul transmission position, find that it does nasty things to my gas mileage, i.e. 1 to 3 mpg less. The owners manual is not particularly good with explanations (good reading if you are a 6 year old) so what my question is about is what are the implications from not uasing that position 100% of the time while hauling. A death notice to my trans? Or....? Yes, I will use it if it is hilly, but flat or mildly rolling roads, with the amount of torque that a 3 valve V10 generates seems to make this overkill in most cases and with gas hovering at $3/gallon, is it really necessary. Watching the trans temp gauge this past weekend didn't indicate any higher readings then without any load. What does the Tow/Haul position really do - lock out overdrive? change the torque converter vane position? (you're right I'm durn engineer and like to know why
