andym
Real men are fanatics
.......which means that a 1:1 ratio can't be achieved and thus allowing for higher RPMs at higher speeds - right?
Yes.
It's like a manual transmission in that the drivetrain is locked together and there is no slipping as you'd find in a conventional torque converter.
With the switch in the off position, the circuit is broken and cannot be completed. The computer cannot ground the wire because it's open.
With the switch in the up position, the computer will control the lockup just as if the switch wasn't there. All the switch does is close the circuit that you opened by cutting the purple/yellow wire.
Down, the circuit is grounded. The torque converter locks up and the computer is powerless to unlock it. Even when the computer tries to open the circuit to send the unlock signal, the circuit is still grounded and the converter stays locked.
Andy nailed it, thats how it works.Absolutely.The torque converter likes to lock too early, robbing power. I think that's the biggest benefit.
It will also help me when driving through the mountains to be able to unlock it when going up a hill. It has trouble keeping up long grades at high elevations (5000 - 8000 ft) - so much so that I usually turn overdrive off to prevent gear hunting. Hopefully this mod will give me more options rather than downshifting to 3000 RPMs at 70 mph. It sucks enough gas as it is.
Yes it can still change gears. Although when I locked mine in during 3rd gear and it changed to overdrive, the shift was not very nice. Like it had to slam into gear since the TC was allowed to slip to make the gear shift smoother.but does it change gears? or when its locked its only got 1 gear and 1;1 ratio?
Yes sir it will. When the torque converter is allowed to slip it allows the engine to rev to a higher RPM for a given speed. Higher RPM = higher torque at the crank (for the most part).Will this help pulling a heavy trailer? Could you explain so this dummy can understand?
OOOoooo look who's suddenly and expert!! Mr. PleaseMakeaWriteupSoICanCopyYouChrisIt also means higher heat because the fluid gets hot in the converter when it's slipping.
And I wouldn't leave it locked while you're stopped. It's bad for the lockup clutches.
I was doing some electrical testing the other day with the switch and I forgot to switch it out of lock before starting the truck. In park there was no difference. When I put it in reverse the RPMs dropped to about 300 or 400 then revved back up and acted normal. I wondered what was wrong until I realized the switch was in lock. It didn't appear to have ANY adverse effect on the truck. It also did not stall or even feel like it wanted to. If you're speculating, then don't pass it off as fact.Bad for the entire drivetrain!!!
Why is that dangerous? Even if the lockup would cause the engine to stall (which I don't believe it would -- see my above text or see Jurgen's in an earlier post in this thread), the brakes still work... I don't believe a locked TCC would hinder the brakes from stopping the vehicle the same way a manual transmission left in gear will not hinder the truck from coming to a screeching halt.Bob Ayers said:It's actually dangerous in an emergency stop situation since there are no provisions to take it out of lockup in a stop!!!
Why is that dangerous? Even if the lockup would cause the engine to stall (which I don't believe it would -- see my above text or see Jurgen's in an earlier post in this thread), the brakes still work... I don't believe a locked TCC would hinder the breaks from stopping the vehicle the same way a manual transmission left in gear will not hinder the truck from coming to a screeching halt.
Here is a real quick writeup for installing a toggle switch for the torque converter clutch on E4OD-equipped trucks.
DISCLAIMER: Use of a manual control TCC lockup switch, as described in the following writeup, can cause your transmission to entire limp mode if used excessively. Transmission damage should not result, and the condition can be remedied by simply resetting the computer. Generally problem will occur if one keeps the TCC unlocked for an extended period of time when the computer is expecting it to be locked (eg, extended drives at freeway speeds). Again -- this mod should not harm your transmission in any way, but be aware that the computer will sometimes have a temper tantrum for not having control of the TCC![]()
I'm not sure how long it takes to throw the code. And no, hard shifting will not cause damage to the drivetrain -- that is the idea behind limp mode. Increases line pressure to firm up the shifts in the case of transmission slippage. The transmission does this to protect itself, not to hurt itself.Chris, how long does it take to throw the code, and the tranny start shifting hard? Don't you think the hard shifting will add additional stress to the tranny, and rest of the drivetrain?
Are you saying that you, or FTF will not be responsible for damages that may result from the suggestion of adding this switch to the TC circuit?
And of course neither I nor FTF are responsible for this mod... This is a discussion board... This isn't a certified Ford TSB or some crazy thing... It just a mod, like all other mods that people do. YOU'RE RESPONSIBLE FOR YOUR OWN MODIFICATIONS. If you don't understand why you're doing a mod, and thus don't know what it may entail, then you shouldn't be doing the mod in the first place.
