Tech thread: TCC Toggle Switch
Here is a real quick writeup for installing a toggle switch for the torque converter clutch on E4OD-equipped trucks.
DISCLAIMER: Use of a manual control TCC lockup switch, as described in the following writeup, can cause your transmission to entire limp mode if used excessively. Transmission damage should not result, and the condition can be remedied by simply resetting the computer. Generally problem will occur if one keeps the TCC unlocked for an extended period of time when the computer is expecting it to be locked (eg, extended drives at freeway speeds). Again -- this mod should not harm your transmission in any way, but be aware that the computer will sometimes have a temper tantrum for not having control of the TCC :rofl:
Materials you'll need:
*3-position (on/off/on) switch
*4 "bullet disconnect" electrical crimp connectors (2 male, 2 female)
*3 small ring terminal crimp connectors (small enough to fit the screws on that 3-position switch terminals, but large enough to accommodate the gauge of wire you're using in the crimp)
*1 medium sized ring terminal connector (large enough to fit around the grounding bolt under the driver-side kick panel --- my guess is that the inner diameter of the ring connector should be roughly 1/8 - 1/4". Just eyeball the size and buy a ring connector accordingly)
*10-15 feet of wire (your choice on size -- I used 14 AWG because I have a HUGE spool of it) [note: make sure that you buy wire that matches your crimp connector size] [note2: I recommend getting 3 equal lengths of DIFFERENT colored wire -- for example: 5 feet red, 5 feet black, and 5 feet green --- this will make it easier when wiring your switch]
[note: it's always a good idea to buy extra crimp connectors and extra wire -- I always screw up on at least one of my crimps and have to redo it]
Step 1: Locate the transmission harness which is mounted on the driverside fender-well of most Gen 8-9 pickup trucks. If you can't figure out which is the right one, get under the truck and trace the wire spool coming from the passenger side of the transmission -> up and over the trans -> up the frame rail towards the engine -> and then up into the engine compartment. Once you have located the harness, you need to locate to the PURPLE/YELLOW wire in the harness. That is, the PURPLE wire with a YELLOW tracer on it.
Step 2: Snip the wire, leaving ample slack on both sides of the cut to strip the insulation and crimp on your connectors.
Step 3: You guessed it --- strip the insulation off. NOT TOO MUCH! You only need a few millimeters of bare wire to crimp, so that you don't leave exposed wire outside of the connector (shorting hazard). To get an idea of how much exposed wire you need, look at the electrical connector your using and look at the crimping section of the connector --- thats roughly how much you should strip away.
Step 3: Crimp a MALE connector onto 1 of the exposed purple/yellow wires and crimp a FEMALE connector onto the other. We want opposing connectors here so that if we ever want to UNDO this mod we can just plug these two back together and return to stock.
Step 4: This step is going to require a bit of your OWN thinking (oh no!!) You're going to want to locate the switch at the blank part of your dash where you plan on installing it, then you'll need to eyeball the amount of wire that will be required to take a piece of wire from the switch, through the firewall, and into the engine compartment where you can connect it to the bullet disconnects that we just crimped. I located mine to the right of the steering column and I believe it took 3-4 feet of wire to get it into the engine compartment. Alternatively, you can drill the hole for the switch and install it, then run an excess amount of wire from the switch into the engine compartment (or vice versa) and cut it when it reaches the proper distance. You will need TWO pieces of wire cut to the proper length. Again --- this step can be performed however you like, just use common sense. If you have no common sense, place the truck in reverse and lay down behind the front tire :rofl:
Step 5: Take your first piece of wire, strip the insulation from the ends and crimp a FEMALE bullet connector to one end, and a ring terminal connector at the other.
Step 6: Take your second piece of wire, strip the insulation from the ends and crimp a MALE bullet connector to one end, and a ring terminal connector at the other.
Step 7: Connect the bullet connectors on the wires to the opposing connectors on the purple/yellow wire in the engine compartment. Then run both wires through the firewall and up to where your switch will be located.
Step 8: Cut a length of wire that is long enough to reach from your switch location to the lower portion of the driver-side kick panel. On this wire you will crimp your third small ring terminal connector at one end and your medium ring terminal connector at the other end.
Step 9: Remove the driver-side kick panel to expose the green-colored grounding bolt located below the hood release lever. Unscrew the grounding bolt and slide your medium ring terminal connector around the threaded side of the bolt, then screw it tightly back in place. Route the wire up to your switch and replace kick panel.
Step 10: You should now have 3 small ring terminal connectors near where your switch will be located -- two from the engine compartment and 1 from the grounding bolt. Remove the 3 screws from terminals on the 3-position switch, and screw the grounding bolt terminal to the TOP terminal on the switch (refer to the ON stamps on the front of the switch to figure out which one is top and which is bottom).
Step 11: Take the wire that is coming from the COMPUTER side of the purple/yellow and connect it to the BOTTOM terminal on the back of the switch.
Step 12: Lastly, take the wire coming form the TRANSMISSION side of the purple/yellow and connect it to the MIDDLE terminal on the back of the switch.
If wired correctly, it should look like this:
Explanation of how this works... The torque converter clutch is LOCKED when the purple/yellow wire going to the transmissions gets grounded. All the switch is doing is choosing when the transmission is going to get ground. Here is what the internals of the 3 position switch look like:
Position1:
Position 2:
Position 3:
As you can see... We're taking either the computer signal from the bottom post, or the ground from the top post, and just redirecting that charge onto the center post -- which goes out to the transmission.
You'll notice that because of the nature of the switch, the top and bottom posts are swapped from what common sense tells you they SHOULD be. The upper position of the switch corresponds to the computer controlling the TCC, and yet the upper POST on the back of the switch is connected to ground. This is because inside the switch is just a solid bar that redirects power, as you can see in my diagrams above.
So thats it for my tech writeup!
TheRoadVirus
High-Steppin' Mo-Sheen
2,461
31
Ontario, Canada
I've got a question, just out of curiosity..
I'm thinking of a way to put this in words.. lol. With the switch in the on position (locked) does it function as if you hadn't done this mod?
No sir. If you put it in the TOP position (auto) it will function as if you didnt do the mod --- which locks the TCC somewhere in the range of 35-45mph. The BOTTOM position (on) locks the TCC in FULL TIME.
surewhynot
Rep whores make me sick
13,843
821
Florida
I wonder, could the truck be push started if the battery is too low to crank it by flipping the switch to on?
Dude... Thats a good idea... **Chris ponders the possibilities**
EDIT: The TCC does need a bit of power to lock in place, I'm not exactly sure how much. The resting position for the TCC is UNLOCKED when it's receiving no power (obviously). So you'd still need to have enough power to lock the TCC. But in theory it should work. The TCC locks the rear driveshaft to the crank. So if you turn the wheels then you're turning the crank.
Don't need to drain the battery to try it, just turn the ignition to ON and roll it down the driveway then FLIP THE SWITCH!
Also, wouldn't I still need enough power to power the fuel pump?
surewhynot
13,843
821
Florida
Yes, but if the battery isn't completely dead, just too low to crank the truck, the fuel pump may work. Obviously, you also need enough power for the torque converter lock.
TheRoadVirus
2,461
31
Ontario, Canada
Hmm, I've never had to worry about the battery not having enough juice when I had to push start my truck. It was only when the starter went that I had to do it to get to work.
Man, did that suck. -20 celsius and my truck wouldn't start.. nearly crashed popping the clutch to start it on the slick roads.
Lost
PA Chapter leader
3,288
central PA
Very nice write up. I may do it after I make a console for the roof . Some centurions and conversions had them . I want a place for fog light switch also.
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
and what happend when its on OFF position?
so letme get this straight.. when its in ON position the converter is locked so its like a manual transmission right? and can it shift gears ?? and the engine would die while coming to a stop right? and will it shift harder? or what? i dunno im confused
andym
Real men are fanatics
604
Roseville, CA
This is a great mod. I think it took me 30 minutes to do, including running to Kragen to get the switch. I tried it out and it seems to work well. I think my torque converter is slipping because it wouldn't die when I came to a stop locked up. Probably not all that good for it. :)
eco
646
12
As I understand it ON (bottom position) is a 1:1 ratio - not like a manual which has the option of several ratios. With the switch ON the trans is stuck with a 1:1 ratio untill you flip the switch to the top position or the middle position. The middle position prevents the completion of the circuit which prevents a 1:1 ratio. Top position completes the circuit - so it's like the mod was never done and the computer has all control again.
Yeah, this is a cool as hell mod. I have an AOD so I won't be able to do it. Skan, how did you come up with this idea?
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
smilieIagree :suspicious: splain in simple terms please.
Great write up BTW!
andym
604
Roseville, CA
It's like a manual transmission in that the drivetrain is locked together and there is no slipping as you'd find in a conventional torque converter.
With the switch in the off position, the circuit is broken and cannot be completed. The computer cannot ground the wire because it's open.
With the switch in the up position, the computer will control the lockup just as if the switch wasn't there. All the switch does is close the circuit that you opened by cutting the purple/yellow wire.
Down, the circuit is grounded. The torque converter locks up and the computer is powerless to unlock it. Even when the computer tries to open the circuit to send the unlock signal, the circuit is still grounded and the converter stays locked.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
so when does this help? I know i can't do it to mine but just curious.
eco
646
12
.......which means that a 1:1 ratio can't be achieved and thus allowing for higher RPMs at higher speeds - right?
andym
604
Roseville, CA
The torque converter likes to lock too early, robbing power. I think that's the biggest benefit.
It will also help me when driving through the mountains to be able to unlock it when going up a hill. It has trouble keeping up long grades at high elevations (5000 - 8000 ft) - so much so that I usually turn overdrive off to prevent gear hunting. Hopefully this mod will give me more options rather than downshifting to 3000 RPMs at 70 mph. It sucks enough gas as it is.
