Suspension?
Hi, I have a '97 F-150 and lately I've noticed that it sits lower on the drivers side than the passenger side. It doesn't seem to affect anything, it still rides nice and handles good. What could cause this? Is it bad shocks or springs or something? Thanks for any help you might have.
surewhynot
Rep whores make me sick
13,843
821
Florida
It is possible for it to be normal spring sag. There is always the weight of a driver, but not always the weight of a passenger to even it out. You might look at the cab mount bushings and see if any are wore out, but my guess would be the spring.
And welcome to FTF. There are some really smart techs that hang out here. Somebody may have a better answer than me.
blackhat620
You Had to be There
1,687
150
Arizona
nosbusch2005,
Welcome to the lunatic asylum.
The left side normally sits lower than the right side, the fuel tank is on the left side. On the SD 3/4-inch from side to side is acceptable per FMC and I am pretty sure the same holds true for the F150.
The adjustment is roughly under the doors, about 1/3 the way across the bottom. Just turn the bolt, until you're satisfied.
Just don't try to do it on the opposite side by loosening it... You'll get an annoying noise during bumps and you'll think you broke something!
Even an 84 painted to look like a 94
Thanks guys for the welcomes and the tips. I adjusted the torsion bars and it looks much better now. I also replaced the front shocks for good measure.
Thanks :beer:
A_G
wuh?
3,188
74
Tulsa, Ok
most old trucks that ive seen always have a lean to either side. Mine leans to the passenger side tho. But i think its cause of my offroad and jumping and my wreck...
