still have a fuse problem
jdk
86
ok i pulled apart the steering colum and changed the fuse. everything worked fine. i put the colum back together and it blew the fuse again. what is the prolem? all the wires look good. i am stumped here. any ideas? thanks jdk
Something is shorting. Does it happen as soon as you put the fuse in, or after you do something.
jdk
86
its ok unitl i put the plastic cover back on the steering coulm then it blows again
jdk
86
and turn the key on sorry
3,291
188
In my own world
does your bell/buzzer work? could be you have the wire to the key switch pinched
jdk
86
no it does not work. sometimes the buzzer for the seat belt works but not always
3,291
188
In my own world
that's a separate circuit, and usually the buzzer just goes bad there. There is a wire going to the key switch, that makes a connection when the key is in. it may be pinched in your plastic, and shorting to ground.
jdk
86
i cut that wire and crimped a in-lne crush connector on it and it still does it. the fuse that blows contorls the gauges and the thing that powers the E4OD
3,291
188
In my own world
Is the wire to your o/d shift pinched where it goes to the column off the shift lever?
jdk
86
what does that wire look like? i can see the selctor indicator cable. everything else looks ok ( the wires to the turn signal switch) and the mass of wires on the left side of the coulm
3,291
188
In my own world
with the plastic off, look at the bottom of the gear shift, the wires come out there.
jdk
86
and that could be an issue with the plastic on?
3,291
188
In my own world
you won't be able to see the wires with the plastic on, plus in your earlier post, you stated that the fuse didn't blow until you installed the plastic. This leads me to believe the plastic pinched, or smashed the wires to the point that they are bare, and being forced to gether, or one is bare, and touchinjg the metal column, being held there by the plastic.
jdk
86
the wire i saw looked like a cable, and it looked ok but idk
jdk
86
Update
ok heres whats going on. Where the shifter goes into the coulm, there is a pin that the shifter pivots on. the pin sticks up about 1/4 in. around the pin and where it goes into the metal, is black from arching. the gauges work, but the transmission will not **** into overdrive and the the touque converter does not lock up. the OFF light at the end of the shifter does not light up and the switch does nothing. if i move the shifter all the way up (to the extreme) the OFF light will flicker when i push the button. the the O/D switch bad? i'm going to try and upload a pic of where its arching at.
jdk
86
update2
i found the problem. the wires were rubbing (i assume) in the shifter its self. i soldered the wire that was broked and wrapped the other 2 withe electric tape and thus far it seems to be ok. thank for the help guys
3,291
188
In my own world
Good deal, glad it's fixed
