Started on the Interior
Cliff, also... one last piece of advice.
Wet sand with your last grit of sandpaper. It'll soften the ability to be an abrasive and almost act like 4,000 grit sandpaper instead of 2,000 grit.
Ridgerunner
573
Stillwater Ok
You mean to sand until it comes clear?
When you're done with your finest piece of sandpaper, get a cup of water and wet the paper of the finest grit you have. The small amount of water (while sanding) does wonders as far as clearing up the abrasion marks from previous sanding.
Ridgerunner
573
Stillwater Ok
Ok I got it,start dry then go wet. Thanks Roy, and Ryan
Ridgerunner
573
Stillwater Ok
Well it done. I went to my local paint supply house to get some 3000 grit pad. The Roger who always waits on me wanted to know what I was doing I explained to him about my dash cluster lens. He recommended this headlight restoration system to me and I tell you it works great. I also used meguires headkight polish afterwards.
http://www.pc-41.com/
Ridgerunner
573
Stillwater Ok
Thanks Roy. It looks good but there are a few imperfections. I will mod my other lens and store it.
Ridgerunner
573
Stillwater Ok
Well Roy I would have quit on it, but you gave me a lot of support and encouragement. Thank You.
Ridgerunner
573
Stillwater Ok
I got the original dash cluster out cleaned it up and repainted the needles and polish the lens
Ridgerunner
573
Stillwater Ok
Here is the circuit board from the tach cluster,you can see where all the contacts are clean and there are no breaks that I could see. I used ketchup and qtips and you can see the 2 in the picture came out clean I got them looking that way.
Ridgerunner
573
Stillwater Ok
Here is my old dash cluster cleaned and needles repainted.
Ridgerunner
573
Stillwater Ok
Hey Roy
Here is the glove box door you sent me it turned out great and fits just right.
Ridgerunner
573
Stillwater Ok
The wife and I went to a yard sale and found a bunch of Ford emblems. I took one that looks like it came from a SD had my son drill a need hole and it looks good.
