mrfixit
Chief Chaotic Engineer
Below is a list of RECALLS on Ford Trucks: I realize this is in the superduty Sub-thread, but there are sufficient super duty,as well as F150,F250,E150,E250 and Excursions, Explorer, Ranger, etc...I will try to keep this updated as I get the recall notices, but if you have any to add, feel free to do so. They are in no particular order yet, but I hope to soon create a database to organize them into a searchable yet readable form.
2006 FORD E-150 RECALL - Wed, 07 Mar 2007 08:19:10 EST [SIZE=-1]Defect: on certain trucks, passenger cars and sport utility vehicles, the windshield wiper motor may have been produced without grease being applied to the output shaft gear.[/SIZE]
[SIZE=-1]Consequence: after a period of continuous use on the high speed setting, lack of grease on the output shaft gear may cause the gear to distort or fracture during operation resulting in a loss of wiper function. inoperative wipers under inclement weather conditions could cause a crash due to impaired visibility. [/SIZE]
[SIZE=-1]Action: dealers will inspect the wiper motor for the presence of grease and grease the wiper motor gears if necessary. the recall began on november 22, 2005. owners may contact ford at 1-800-392-3673 or lincoln/mercury at 1-800-521-4140. [/SIZE]
[SIZE=-1]Manufactured between: 08/29/2005 and 10/17/2005[/SIZE]
[SIZE=-1]Recall Date: 11/09/2005[/SIZE]
2006 FORD E-250 RECALL - Wed, 07 Mar 2007 08:19:10 EST [SIZE=-1]Defect: on certain trucks, passenger cars and sport utility vehicles, the windshield wiper motor may have been produced without grease being applied to the output shaft gear.[/SIZE]
2006 FORD E-350 RECALL - Wed, 07 Mar 2007 08:19:10 EST [SIZE=-1]Defect: on certain trucks, passenger cars and sport utility vehicles, the windshield wiper motor may have been produced without grease being applied to the output shaft gear.[/SIZE]
2006 FORD E-450 RECALL - Wed, 07 Mar 2007 08:19:10 EST [SIZE=-1]Defect: on certain trucks, passenger cars and sport utility vehicles, the windshield wiper motor may have been produced without grease being applied to the output shaft gear.[/SIZE]
2005 FORD E-450 RECALL - Wed, 07 Mar 2007 08:19:10 EST [SIZE=-1]Defect: certain pickup trucks, sport utility vehicles and vans equipped with 6.0l diesel engines may experience stalling without warning while driving and may or may not restart. [/SIZE]
[SIZE=-1]Consequence: should the engine stall, a vehicle crash could occur.[/SIZE]
[SIZE=-1]Action: dealers will upgrade the fuel injection control module (ficm) wire harness or replaced, and/or have a new injection control pressure (icp)) sensor connector installed free of charge. the recall began on july 22, 2005. owners may contact ford at 1-800-392-3673. [/SIZE]
[SIZE=-1]Manufactured between: 03/31/2004 and 05/19/2004[/SIZE]
[SIZE=-1]Recall Date: 06/10/2005[/SIZE]
2005 FORD E-450 RECALL - Wed, 07 Mar 2007 08:19:10 EST [SIZE=-1]Defect: certain cut-away incomplete trucks equipped with lt225/75r16e tires fail to comply with the requirements of federal motor vehicle safety standard no. 120, 'tire selection and rims for motor vehicles other than passenger cars.' the tire pressure is incorrectly listed on the label for the rear tires.[/SIZE]
[SIZE=-1]Consequence: at the incorrectly stated pressure, the rear tires are unable to support the gross axle weight rating (gawr) for the rear axle.[/SIZE]
[SIZE=-1]Action: owners and dealers will be mailed supplementary tire labels containing the correct rear tire inflation information. the recall began on january 11, 2005. owners should contact ford at 1-800-392-3673. [/SIZE]
[SIZE=-1]Manufactured between: 10/26/2004 and 12/02/2004[/SIZE]
[SIZE=-1]Recall Date: 12/20/2004[/SIZE]
2004 FORD E150 RECALL - Wed, 07 Mar 2007 08:19:10 EST [SIZE=-1]Defect: on certain vans, the air filter element material process resulted in an air filter paper element that can smolder or burn. this change in filter paper composition combined with the configuration of the air induction system, may allow hot carbon particles to contact the air filter element during certain driving conditions that create hot particles. [/SIZE]
[SIZE=-1]Consequence: these hot particles may ignite the air filter element with the potential for air induction system damage or underhood fire. [/SIZE]
[SIZE=-1]Action: dealers will inspect and replace the air filter element. the recall began september 27, 2004. owners should contact ford at 1-800-392-3673. also ford is extending the limited warranty (for a one time replacement) of the abs module for a total of 10 years or 150,000 miles from the warranty start date, whichever occurs first. if your vehicle has already accumulated more than 150,000 miles, this coverage will last until september 30, 2005. [/SIZE]
[SIZE=-1]Manufactured between: 04/23/2002 and 04/30/2004[/SIZE]
[SIZE=-1]Recall Date: 09/13/2004[/SIZE]
2004 FORD E150 RECALL - Wed, 07 Mar 2007 08:19:10 EST [SIZE=-1]Defect: on certain vans, a diode in the anti-lock braking system (abs) module may experience an electrical short. [/SIZE]
[SIZE=-1]Consequence: the electrical short may cause an abs malfunction that would illuminate the abs warning light, or the module may overheat resulting in a burning odor, smoke, and/or fire. this condition may occur while the vehicle is being driven or unattended. [/SIZE]
[SIZE=-1]Action: dealers will install a new fuse in the abs circuit and install a heat shield over the abs module. the recall began on october 15, 2004. owners should contact ford at 1-800-392-3673. also ford is extending the limited warranty (for a one time replacement) of the abs module for a total of 10 years or 150,000 miles from the warranty start date, whichever occurs first. if your vehicle has already accumulated more than 150,000 miles, this coverage will last until september 30, 2005. [/SIZE]
[SIZE=-1]Manufactured between: 04/23/2002 and 11/19/2003[/SIZE]
On to page 2
On to page 2
