surewhynot
Rep whores make me sick
One day I'd like to have him stroke a 400 for my scout.
Keep in mind that I went carb'd. I'm not sure how my setup, even as mild as it is, would work with efi.
Yeah, eagle or scat seams to be the best w/ preference going to scat..
OK IVE DECIDED WHAT IM GOING TO DO FOR NOW!! here it is:
MAF SWAP!
Explorer intake from 96/97
GT40 Heads 96/97
Long Tube headers that will fit a lightning (lightnings came with GT40 Heads)
COMP Cams 35-414-3 OR... do yall have a though for a different cam? cause from what i understand this cam makes better power at higher rpms.
FYI.. You need a 5.8 GT40 lower for that Explorer upper.
Any F150 longtube will work but the cheap Flowtech and Headman longtubes don't fit too well, have heard the Pacesetter longtubes fit much better.
That's a flat tappet cam and you have a roller motor. There are quite a few suitable roller cams available including the Ford E303 and the Comp cams Magnum 270 and 280, see the attached pic below. The powerband will be below 5000rpm with those heads on a 5.8 so there's no point spooling the motor beyond that. The Magnum270 produces the most TQ of these 3 while the E303 produced the least, the Magnum280 matches the E303 in HP and produces more TQ. You'll need matching valve springs for all of these.
The Pro Products Typhoon is an Eddy Performer copy and is about equavelent to the GT40 in performance, it's also half the price of the Edelbrock intake but that's because the exterior finish isn't quite as nice. The Magnum 270 would be my choice too for a truck motor.. lots of TQ to get it moving. No need for higher octane fuel here, that's based on engine compression and that won't be much different than a regular motor.
