Rapid Loss of Oil
123
6
As of late my truck has been usin a ton of oil. There's no leaks of any kind.What should I be looking for or do?
Sounds like your gonna need a rebuild soon, IIRC generally burning oil is due to bad piston rings but I'm no mechanic. The good thing is a rebuild on a 460 is nothing compared to say a modular or a 6.0.
384
sometimes the burning of oil is so minute that you dont notice it until you stomp on the gas..
my dads 95 F150 w/302, 135k miles is burning oil and when he stomps it i gives a good blow of black smoke looks kind like a diesel... haha
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
Chris, Kinda the same issue with mine. It doesn't smoke that I know of, but when I stomp it, I can smell oil burning.
TexasNomad
FTFS Designated DRINKER!
If your burning oil your plugs should show some build up or funky coloring.
Give us a little more info, does it smoke? How hard does it smoke? Just on start up? Or all the time? Could be something as simple as valve seals or some other gasket or seal on up to needing a bottom end rebuild. Also check the block for any witness marks.
123
6
She smokes but only on start up and it's not a really noticable.But you can defnately smell it sometimes.Me and my dad were lookin at gettin another 460 from a friend of his.
Typically, that's a valve seal issue...but rarely does it result in a rapid loss of oil.
