your trans crossmember is loose. raise the trans enough to take the weight off it, loosen, then tighten the trans crossmember, then set the trans back down and tighten it. what you are hearing, as far as the pop goes is the crossmember flexing when the frame is racking.the poping travels through the trans, and will cause you to spend a lot of money on the front end parts
