Ok folks, a little more involved
420
I've seen head gaskets make an entire bank go low... but it would be possible for the one tooth to change the compression a bit I suppose... haven't dealt with dual overheads much. Rather have a chain if I can...but if the time is off late, it could bend all the valves on that bank too, if it is an interference motor.
It seems ford didn't learn anything buying Jaguar, or jaguar didn't tell them everything :rofl:
blackhat620
You Had to be There
1,687
150
Arizona
I vote "a" timing chain off one tooth. Vacuum leak won't do it, but off one tooth on the timing chain can cause one bank to have an open valve in all cylinders since on a dual cam setup one cam works the intake valves and one works the exhaust valves.
.... since on a dual cam setup one cam works the intake valves and one works the exhaust valves.
Ummmmm, on a DOHC V-8, I do believe that is physically impossible.
But read my retraction below, because I was wrong.
Actually, thanks to the help of a very smart friend, I found out there are such engines about.... my apologies. But at least I looked into it, right?? Oy.. to be me sucks sometimes.
So is the fact that you're still alive, but yet, you keep posting. :rofl: :nana: :rofl:
Just cuz you can't keep up is no reason to taunt....
Hell, I gave up keep'n up with you.......so I just yield the floor to you...
Good thing; I'd mop it with you.... Nooooooo I wouldn't, yer too nice of a guy for that. But it DID sound funny, didn't it?
