Missing
my 02 F250 with a 5.4 is missing. It misses on acceleration only and smoothes out usually after gaining speed and letting off the throttle. Idle is very smooth. I appreciate any advice.
3,291
188
In my own world
Check the codes. The truck will tell you what's wrong with it
Mine wound up being a bad coil pack
Thank you DB. Hopefully my son will be able to bring his analyzer by but I amy have found the trouble. Water all around the 3rd cylinder back. All around where the boot goes down to the plug. I better go dive into it. Thanks again.
Look at your heater hoses and the weather stripping. Heater hoses can develop leaks at the connections on the heater core. The coils are just below them. Same for the weather stripping.
Good point blacksnapon. Rattle can advised me to keep chasing those coils. I did ohm the resistance os them and the injectors but of course that won't show a partially or blocked injector.
