Ridgerunner
Anyone rebuild their truck with junkyard parts?
That truck is the reason why I haven't been here much. So it's either that or scrap yard.Sometimes depending on the part
certain parts yes... what parts are you needing?
is your wiring system hacked up or something?
have you pulled codes? that'd be the first place i'd look is for codes and wiring system... then get the ECU checked to see if its ok...
shouldnt be hard to get a replacement wiring system and fuel system for it... they are pretty common...
Did you try a TFI module?
Doesn't your truck have trans problems?Cliff, you should just scrap it and come buy my truck.![]()
You just don't know what your buying at the yards, as far as engines and transmissions. And electrical. And fuel supply. And , and and , and ,
