IVE HAD IT with this clutch system and manual gearbox!!
416
Use and abuse also come into play. For someone running a stock setup, and not spinning the motor as fast, it may not cause trouble as much, but for race type applications, the stress is severe. That is why scatter shields are required for racing when you get fast enough. Should be required for most all though, but is unrealistic dealing with stock apps.
blackhat620
You Had to be There
1,687
150
Arizona
"brittle" does not mean -weak-.
"brittle" is only how it -failed-.
"it broke" as opposed to "it stretched, then broke".
Glass, ice and peanut brittle are bad examples of
things that can be both strong and brittle. ;)
Some of that stuff on ARP's website was re-written
or polished-up by a writer/salesman looks like. :/
L19 sounds like a L-series tool steel nothing more.
Almost all tool steels are arc + vacuum remelts.
H11 tool steel is mentioned but defined, wasn't
"cool" enough for the sales staff? LOL :)
"ARP2000" LOL :)
But not judging a company or it's products by their
website or sales staff, ARP really does know their
stuff looks like. At least they friggin mentioned L19
and H11 just for me! LOL :)
Notice they mentioned the "“temper brittle zone”
(between 500° and 700°F)"? Well, here's a graph
showing it in action...
http://www.panix.com/~alvinj/file12/graphL6.jpg
Alvin in AZ
blackhat620
You Had to be There
1,687
150
Arizona
Alvin,
I realize the "brittle does not mean -weak-", but if a material is to brittle for the load characteristics then it will prematurely fail by fracturing. Concrete is brittle, but extremely stong in compression, however in tension it performs very poorly. All fasteners and support members must have the proper amount of elasticity (plasticity) for there desired application. The ARP link was just a quick simple way to allow those who wanted a brief look at fastener characteristics the ability to do so, not teach a multipart course in fastener characteristics and strengths of materials.
As you know when the strength of a matierial has reached its limit, it will either "deform or fracture" depending on how malleable and/or ductile the material is. A material that has a high "fracture toughness" will generally under go "ductile fracture", where as a material that has a low "fracture toughness" will under go "brittle fracture". If someone wants to learn more about "brittle fracture" a good starting point would be to study A. A. Griffith's and G. R. Irwin's work, and Fracture Mechanics in general.
www.imechanica.org/node/449
www.springerlink.com/content/n588040426n026t6/
www.sv.vt.edu/classes/MSE2094_NoteBook/97ClassProj/anal/grealis/history.html
www.sv.vt.edu/classes/MSE2094_NoteBook/97ClassProj/exper/gordon/www/fractough.html
www.sv.vt.edu/classes/MSE2094_NoteBook/97ClassProj/exper/gordon/www/summary.html
www.sv.vt.edu/classes/MSE2094_NoteBook/97ClassProj/glossary.html#fracttough
http://en.wikipedia.org/wiki/Fracture_mechanics
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
i found out that on the pressure plate im using grade 12.9 bolts
i said to the guy at the store gimme the strongest ones and these are grade 12.9
i found out that on the pressure plate im using {class ;} 12.9 bolts
i said to the guy at the store gimme the strongest ones...
Those are strong suckers! LOL :)
Wanted to snip-out just the two tables in the middle of the page. :/
Anyway, check out their hardness compared to grade-8's for example. :)
http://en.wikipedia.org/wiki/Screw
What thread is your 12.9's? :)
Are they metric or standard?
I've got examples of bolts going "both ways" they can-be Bi or something. ;)
Alvin in AZ
H11 tool steel is mentioned but {not} defined,
{H11} wasn't "cool" enough for the sales staff? LOL :)
"ARP2000" LOL :)
Not ARP2 but ARP2000. LOL :)
Salesmen huh? ;)
Can't trust 'em, can't kill 'em and our industrialized
world would come to a screeching halt without 'em. :)
Alvin in AZ
F 150Cobra
3,642
104
Aruba
Alvin in AZ
i dont know i just took the flywheel to the shop and got the bolts for it.. but they are L wrencht heads tough!! i gotta use a special adapter!... im staying with these 12.9 !! just got add loc tite and lock wash
416
I believe 12.9 is a metric designation...
blackhat620
You Had to be There
1,687
150
Arizona
Yes you are correct, 12.9 is the International (SI) (ie metric) class designation.YelloThumbUp
What thread is your 12.9's? :) Are they metric or standard?I've got examples of bolts going "both ways" they can-be Bi or something. ;) Alvin in AZ
Alvin if they are designated class 12.9 then they are International (SI) (ie metric), and since they are metric they will be "metric coarse" thread unless they are specifically stamped "metric fine" thread. There is no North American Imperial thread (ie standard thread) available on SI bolts.
blackhat620
You Had to be There
1,687
150
Arizona
Jurgen,
Yes 12.9 bolts are strong, but they are designated by "Class" not "Grade". International (SI) (ie metric) specify there bolts & screws by "class", while North American SAE (Society of Automotive Engineers) specify there Imperial bolts & screws in the J429 specification by "grade".
SAE J429 is for Imperial sized bolts & screws (North American) and defines them by “grade” with a range from 0 to 8 with 8 being the strongest. Higher grades do not exist within the specification.
The International Standard (SI) for metric bolts & screws is ISO 898 (SAE J1199 & ASTM F568M) are North American metric standards that are similar to SI ISO 898. ISO 898, SAE J1199 & ASTM F568M define bolts & screws by “class”, with a range from 4.6 to 12.9
SAE J429 Grade 5 = Class 8.8 ISO 898 (85, 92, 120ksi) Proof/Yield Tensile
SAE J429 Grade 8 = Class 10.9 ISO 898 (120,130,150ksi) Proof/Yield/Tensile
ASTM A574 (140, 153, 180ksi) similar to Class 12.9 ISO 898 (140,160,177ksi) Proof/Yield/Tensile
Note: There is no equivalent SAE grade to ISO 898 Class 12.9.
Caution is advised when considering the use of Class 12.9 products. The capabilities of the fastener manufacturer, as well as the anticipated service environment, should be carefully considered. Some environments may cause stress corrosion cracking of non-plated as well as electroplated products.
SAE J429 Grade 5 has the same Proof, Yield & Tensile Strength as ASTM A325, and SAE J429 Grade 8 has the same Proof, Yield & Tensile Strength as ASTM A490. However a Grade 5 is not interchangeable with an A325, nor is a Grade 8 interchangeable with an A490 fastener. The reason is the construction of the fasteners. SAE J429 fasteners have a “Standard Hex Cap Screw” configuration whereas the ASTM A325 & A490 have a “Heavy Hex Head” configuration. The “Heavy Hex Head” configuration has a wider bearing surface to distribute the load over a larger bearing surface. Also on A325 & A490 fasteners the grip length (non-threaded portion of the body) is longer than on SAE J429 fasteners. The longer grip length of the A325 & A490 result in a stronger tensile connection and a higher shear load rating. The shorter grip length (longer thread length) of SAE J429 fasteners also results in a higher incidence of deformation failure, as a direct result of the SAE J429 fasteners being more ductile. Therefore even though the Grade 5 – A325 and Grade 8 – A490 have the same Proof, Yield & Tensile Strength respectively, the SAE J429 & ASTM bolts are not interchangeable.
As i said before, going with a stonger (ie higher grade or class rating) is not always a better option, if the design characteristics of the particular fastner are not considered as well. In the case of Class 12.9 bolts, they have a low "fracture toughness" and are more susceptible to "brittle fracture", than a class 10.9, 9.9, 8.8 etc.
