HOW TO TELL??? (need fast responce)
fords4life91
"The best NEVER rest"
I am looking at a 1994 f250 diesel 4x4 manual trans. How can i tell if its a "turbo" diesel without actually looking at the truck. I have the pictures of the truck is there anyway i can tell without seeing the motor? Could i use the VIN to tell if it is or not??
polarbear
just growing older not up
12,878
607
Boring, Oregon
I guess I'm not understanding the question. In '94, wasn't there a turbo-diesel and then the Powerstroke?
fords4life91
Nope there was the 7.3l IDI witch was NOT turbocharged and like half way through 94 they switched over to the 7.3l powerstroke which was the turbocharged diesel.
7,086
459
upst ny
not without seeing the door tag or seeing under the hood
fords4life91
OPPS!! made a mistake the 7.3L from 93-94 is turbocharged! I am sorry for corrrecting you when i was wrong now i feel really dumb lol!
So I will be getting a pic of the motor tomorrow hopefully one of you can teel me if its the IDI or the powerstroke!
Most if not all 94's were turbo'd, while it was an option in 93. All the VIN will do is distinguish between a Stroker and an IDI.
If you can see visible injection lines, it is an IDI, they come to the inside of the valve covers. A Stroker will have no visible fuel lines.
In 94 they offered three engines:
1) non-turbo IDI 7.3L
2) turbo IDI 7.3L
3) powerstroke (turbo) 7.3L
The switched from IDI to Powerstroke halfway through the year.
Mr. Stroker
CASE IH
3,121
67
Michigan
I looked at a 94 F350 that was turbocharged but not computer controlled..
Mr. Stroker
CASE IH
3,121
67
Michigan
I knew you was going to say that.... lol
polarbear
12,878
607
Boring, Oregon
2) turbo IDI 7.3L
I have been wrong before, mind you, but I thought the Turbo IDI came out in late '93, and the PSD replaced it in mid-year '94. I remember there were a lot of pizzed owners that bought the Turbo'd IDI, then were looking at a PSD not long after.
Mr. Stroker
CASE IH
3,121
67
Michigan
94 and a half is when they went to computer controlled or aka Powerstroke.
You're absolutely correct. The 7.3L IDI was offered through ~94.5, and after ~93 they offered it with a turbo option. At 94.5 they replaced the IDI with the PSD. So count the engines-- a 94 Ford could have had any of those three engines, depending on when it was manufactured and (if in the earlier half) whether or not the buyer wanted the turbo YelloThumbUp
A_G
wuh?
3,188
74
Tulsa, Ok
with a good picture (good angle) you will be able to tell its a Tubro diesel. Otherwise your screwed.
on most of 7.3's there pretty far up the passenger side of the engine IIRC.
