Hot on startup
bucks77ford
We will Rise Again
2,409
101
Kasson, Minnesota
Sometimes the more you mess with things the more problems arise. If it works and don't leak, I'd also leave it. When I was installing my gauges I used the copper tubing for the oil pressure and it was working, but I didn't like the way I ran the tubing (wanted to clean it up a bit), so I decided to do it over and then I ended up messing up the end fitting and what not and I couldn't get the thing to stop leaking. My Napa didn't carry just the little acorn compression fittings so I was stuck at the time and needed to get it working, so I used the plastic tubing supplied with the gauges and it is still that way. I may just leave it or I may have to get a new copper line set and do it over. I kinda just hate the thought of using the plastic tubing.
