Hi everybody
2,285
193
Los Angeles
Nope, it's a 235. (Pretty much same engine though I believe.)
And thats a pretty good thing to know! YelloThumbUp
It's actually not runnin right now though, it was runnin fine. Then I let it get wet (the hood leaks 'smiliedoh') and it started missin and fouled out my plugs, put new plugs in double checked the points, new fuel filters, and it still aint running very good AT ALL. Owell...gives me somthing to do once it warms up I guess.
It should be pretty easy to get goin' for you. It's a good one to learn on, that's for sure.
You don't have to worry about the dippers on a 235 - they have pressurized oil running to the rod bearings.
The 216 has little troughs in the oil pan - there's a tube in each one that supplies oil from the pump and the little dipper on the con rod scoops it up from the trough. About 8 or 10 psi oil pressure's all you get on those.
Sorry about the Chevy talk *awaiting infraction*
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
Yea...I'm runnin about 30-40psi oil pressure I believe.
http://www.hotrodders.com/forum/questions-about-my-current-project-142632.html
is a link to where I have posted all my questions etc. about it...YelloThumbUp
