msb71
Virginia Chapter Leader
My truck has a single tank on it, had a 16 gal. but like you mentioned i got tired of filling up so much , swapped it for a 32 gal bronco tank. now I only fill up 1.5 times a week.
My gut says take the vin number down to the DMV and have them run it for you.
I'd have them run the plates first, and see if the reg matches the VIN. Yes sir, thats just about right. I believe the tank on these, Mike, is about 18 gallons.Wow- I don't think I've ever seen one with a single tank. What is that, 150 miles between fills?
I typically fill up when I've got about 1/4 tank left (according to the gauge) and it takes about 15 gallons.Mine was 16 Chris, never put more than 15 in it, remember I put a Bronco tank in mine.Now holds 32 gal.
More like 160.... 110 with a bad O2 sensor...What is that, 150 miles between fills?
you need to do a tank swapYes sir, thats just about right. I believe the tank on these, Mike, is about 18 gallons.
Yeah it's on my list of things to do.you need to do a tank swap
Really? I didn't notice!!And yeah, it's a PITA. Especially on long trips. REALLY inconvenient when towing.
I could use BOTH of them in my climate.![]()
My '89 F150 4x4 reg cab short bed had two tanks. I'll get the window sticker and see if that was an option.My '89 F-150 has the single tank. All the regular cab shortbed 4x4's had just one tank. Since that's how Chris's truck started life, that's what he has although there is plenty of room under there for another tank.
They put the t-case in the same location for both the SWB and the LWB trucks, I'm betting it's because it's a short bed and there was less room between the axle and the front of the bed because the one in my '93 fills that space fully......I think the reason the 4wd one's didn't have the front tank is because there wasn't enough room to squeeze it in with the tcase in the way...
Our theories are one of the same.They put the t-case in the same location for both the SWB and the LWB trucks, I'm betting it's because it's a short bed and there was less room between the axle and the front of the bed because the one in my '93 fills that space fully...
EDIT: Ian beat me to it...
