- 14
- 0
91 E350 Clubwagon 5.8 auto. Fuel injected. My front tank fuel pump doesnt always turn on and the truck cranks but won't start. Usually I can hear it turn on when I cycle the key to accessory but now it works maybe 25% of the time. It ran great all winter and on the first warm day it started acting up. Sounds like classic electrical issues to me. The rear tank pump stopped working intermittently and then completely died two years ago while I was driving so I've just been rocking the front tank ever since. I'm suspecting the relay might be faulty and maybe the rear pump is just dead. Hard to say. I want to start by replacing the relay and checking electrical before I throw a pump or two at it or start looking at the computer/wiring. But Im not sure where the fuel pump relay is located. I found two relays next to the battery. Not in a fuse box or anything just laying loose. The only fuse box I've seen is under the driver side dash. Not sure if it's one of these? See the photo with the part numbers. Or is it located somewhere else? I read it may be on the passenger side interior. There is a relay there too but it only has 3 pins. I think the fuel pump relay has 5 pins looking at what O'Reilly's had in their computer system. The part numbers next to the battery are: 913157 and 913182. Is it one of these? The one under the dash passenger side didnt have a number with a red rubber top and I dont know if it's original. There is no CEL coming on and I cant read codes off the OBD1. Google took me down a confusing rabbit hole so I came here to ask the experts.
Sent from my SAMSUNG-SM-G930A using Tapatalk
