- 106
- 1
There are two types of fan clutches "Thermal & Non-Thermal". Non-Thermal fan clutches always spin at 60% of the water pump speed regardless of ambiant temperature. Thermal clutches spin anywhere from 20% - 90% of water pump speed depending on the ambiant temperature coming through the radiator.
There are three grades of Thermal clutches, Standard duty spin at 50-60% water pump speed when fully engaged; Heavy duty spin at 80-90% of water pump speed when fully engaged and have a fin surface area of approx 47 sq in; Severe duty spin at 80-90% of water pump speed when fully engaged and have a fin surface area of approx 65 sq in. The larger surface area allowes the fan clutch to operate more efficiently and have a longer life span in High heat & load applications.
www.haydenauto.com/installation/faqs.htm
All Thermal fan clutches still spin at approx 20% of water pump speed in cold ambiant temperatures (ie disengaged.
Non-Thermal fan clutches spin at 60% of water pump speed regardless of ambiant temperature.
I perused the link.
I don't see the 20% figure anywhere. There is no mention of how many turns per water pump turn with a thermal clutch that is not engaged. That being said, I will repeat myself....where did you get the 20% figure??
Going by feel, a thermal clutch (heavy duty) when not locked has about as much drag as a non thermal. Since they provide figures for the non thermal, I assumed that the unlocked thermal would be near the non thermal when unengaged. But, since the amount of drag would vary with temp, the 60% figure would just be an average. This is how I got the 60% figure fo the thermal clutch.
contest.
