- Moderator
- #21
Okay Duncan why such a high stall speed on the converter????
Well...let me clarify..could be between 24-2600...next step down was 22-2400. It boiled down to what was going to be more fun
Well...let me clarify..could be between 24-2600...next step down was 22-2400. It boiled down to what was going to be more fun![]()
Max torque should be achieved at 3200-4000 rpm, which should be around 525+ at the crank. Cam duration is 224/232 @ .050...roller. Rpm with gears in place should be roughly 2600 at 70 mph with 32's...hence my thought of dropping the gear to a 3.73...which would bring it to roughly 2700. The flipside is that it could stall at 2400 ish...not really going to know 100% until it is driven.
Both the TC builder and transmission builder are good...everything from heads to cam etc. were discussed with the TC supplier. Also keep in mind that both 1st and 2nd gear sets are changed to keep the revs higher. And it goes without saying, but I'll say it anyway....the temp will be monitored..this is not a cheap transmission..I have no intention of frying it![]()
Don't worry, it will happen![]()
Yes but will that occur in this century?![]()
What do you need that for ?
To see if there is an exploded view and what that spring in front does...I need to clean it before getting it dryfilmed.
What is this "dryfilm" you speak of? Some sort of corrosion inhibitor I assume.
