- 67
- 2
Thanks for all the input and feedback. Not distributor, weeding that one out, and even put a new cap and rotor on. Wondering what else it could be if it were ignition though? Will not stay running at all now.
The crank is hard to turn at some points, getting it to TDC, which is making me wonder if something else could be wrong, but that might just be the compression in the cylinders.
I have confirmed that I put the new top sprocket on at the exhaust stroke versus compression (when it is set at TDC with the harmonic balancer marks, and double checking that by pulling plug number 1 and the valve cover, watching the valve movement on 1, the distributor rotor has to be set 180 off from #1 plug wire to run the engine at all now).
There is also an obvious small leak around various edges of intake manifold gasket where it meets heads and engine block. Though may not be related.
So here is what I am going to do:
Take the front engine apart again and reset sprockets. Will remove valve covers again to watch the valve movement. But also thinking should go ahead and take the top part off as well (intake manifolds and heads), but I will check back here before I do that part. Any specific things I should be looking for in this process that haven't been mentioned yet? If sprocket is 180 off which I presume, that would make sense as to why it keeps going out. Or as someone else mentioned 1 tooth off, or both, 180 and 1 tooth off.
Ok, so, there is the temp valve, or switch, with 2 ports, and I replaced it recently, but was not hooked up that way (so was hooked up wrong). So vacuum hose connection should be as follows then:
I figured out other issues now that heads are off (post picks later.
