You can bolt a strip of metal or wood across the TC from mounting bolt holes to hold it in.
You might need a wedge between the strip and the TC.
You want to have a little bit more lift to get it up off the crossmember a bit...
So , is it out ? .![]()
Feel free to leave your beach and get down here in the 100 degree heat to help me out Mark!![]()
Most Ford engines have high torque specs at low RPM
GM engines are short stroke Higher Torque specs at Higher Rpm.
The guy must be a Chevy nerd.
You generally want your tq converter to come on just before peak tq, so sat your peak was at 2500, a 2200iissshhh stall would work well. While stoke and bore do play a part in power bands, the cam/head/intake selection play a much bigger role. It really depends on what has been done to your engine to make an educated choice that will work well with your motor. If you have no idea and were happy with the way it was performing before, keep it the same.
^^^Dunno what it is, but I've never had any luck with transmission guys. I've never gotten a transmission back that I didn't have to bring back within a week.
I had a C6 rebuilt before this truck and I didn't have any problems with it ever... that was at AAMCO too. You'd think these smaller shop guys would pay more attention to detail.
I think it's more or less comfort level with each transmission. With how many transmissions are out there, you can't expect to be an expert on every one...but dang, the C6 should be the easiest one to pass through the shop.
x2 ...and right into the dumpster out back.C6 should be the easiest one to pass through the shop.
