Sorry if this is posted somewhere else, but i'm in the process of removing my transmission and was wondering if it's feasible to just remove the transfer case still attached to the transmission like all in one piece?
Only a few extra bolts to get the tcase off and it'll be a whole lot easier to move around. Plus the tcase is so heavy I'm sure it would throw the balance of your jack off.
^^^Tell that cop his tighty whiteys are a little too tight, if that's enough 'attention' to get you in some trouble...hahahaha. Either way, good luck with it and watch your face...with that kinda weight, if something slips or wobbles you might become a Charles pancake.
. Gonna take a pic of the crossmember underneath the transfer case because I've never seen one like this...
You mean the cross member that has 4 bolts that have access holes in the floor board ?![]()
lol Mine's not so bad in that way...I can squeeze a box-end wrench up top for a back-up and use the socket wrench to loosen those. I just dont remember seeing so many damn bolts holding that sh!t onto the frame. There are 4 up top, 4 on the bottom, and 4 on the driver's side for the little rubber mount -![]()
Using just a floor jack is scary with a 2wd... Need to either get one of the converter pieces, or you can take and weld flat plate on to a shaft or pipe and take the saddle out of the jack and put the plate in it's place. Done that quite a bit... Too bad you weren't closer, I have the converter which I probably will never use, and an actual tranny jack...
