Bucket Seats?
TexasNomad
FTFS Designated DRINKER!
when i put in my buckets it took a drill and drill bit plasma cutter and a welder and a 30 of PBR. first off not sure what bucketts i had but they sorta fit so we positioned them in the cab, marked holes with a handy dandy sharpie and drilled holes. then since i really didnt fully trust the floor we welded 1/8" steel(with holes cut out of it) on either side of the holes and bolted 3 of the 4 down, for the 4th it took a vertical bracket(homemade) with 1 more 1/8" steel "support" on the underside of the truck
I think I read on another site somewhere that If you take the rails from your truck, they will bolt up to most seat setups up till '94 ish
Bench seats will all match up from 73-96.
How bout superduty seats in my 85? Dad wants to put em in.
You can make anything fit. But it won't be a direct swap. With 73-96 bench seats, all you really have to do is swap tracks, or use the existing holes. IIRC, the SD seats were a little wider and makes it a tight squeeze, but I know some guys who have done it. I even know a guy who took a '03? 150 King ranch 60/40 seat and put it in his dentside. So anything can be made to work.
