- Moderator
- #41
Nope, no links, but have seen some pass through ebay from time to time.
I would drive that 8 days a week. That would be a fantastic truck! That Duramax is a great motor.If anybody disgraces a ford truck and puts in a durachoke into a ford, they should be kicked in the nuts by a pro- punter. Then have there eyes and ears filled with bleach.
I can see the point there...
Personally i think the cummins swap is becoming over done.
Cat swap would be pretty damn neat though!
Keep the 460 and send the Cummins to me...
No Cats there, a few Cummins and a Detroit...
I don't know what you guys did to your trucks, but my dads have been farm trucks, used hard and the only problems (other than routine maintenance) we have had is a wheel bearing... Been very reliable, and cheap to run, especially when you factor in the great mileage.We renamed them FIXAMAX
You are right, maybe things will change now that Ford is making their own engine.Yup Isuzu dose make make a good Diesel engine, Navstar does not...
You hope wrong. We have had two 2500s, one 2000 and one 2004, both Duramax. If you compare them to a Superduty of the equivalent year, I would choose the duramax based on the powertrain alone. That truck flat out pulls.![]()
I know how you are, so im fairly sure your effin with me right now...
I hope so anyways!
I have heard of the dt466...
that would be interesting swap...
Haven't seen the cat though.
have any links by chance?
Here's a pic of a DT360 in a 99 Sooper Duty(I can link to a video of it doing a burnout too), and a Cat C7(3126) in a 90-something F350. I thought I added those pix to my Low Buck Site, but I'll have to fix that soon. I almost went thru with swapping in a DT466 in a SD, but had to back out. This time around, I'm going for the "All Ford drive train". A Sterling will replace the 9".
Anyone got a 6.0 they want to donate to me so I can stuff it in my truck?
