yea i was think about maybe going to 4.56's but didnt know what the affects would be cause i know 4.10's would do it nice. but yeah my speed sensor is on top of the rear axle housing. but anyway with the 4.56's, i know i will get more power, but will it guzzle gas crazy? i wanna at least burn rubber more easily from time to time but also want mpg in the long run across town or across state.
oh yea and would it be best to have stronger axles in mind with 4.10's, big lift, big tires?
and what about just showing off with some 40 inch tires on the streets. ? i ran 40's with 3.55's just cruising it did alrite and i aint thinkin of doing any hardcore mudding maybe some hills and trails just throwing this out there
yea i was think about maybe going to 4.56's but didnt know what the affects would be. but anyway with the 4.56's, i know i will get more power, but will it guzzle gas crazy?
You need 4.56's just to get back to the stock final drive ratio and even more gear if you want to amplify engine power. This gear change will actually improve milage and drastically lengthen the life of your transmission.. which you are currently killing every time you drive the truck.
That would be about right. It takes more to get going, which makes more heat in the converter. On a manual, it is harder on the clutch.I never understood why there was an issue for the tranny. Is it because it takes more to get it moving which causes more stress and then when cruising it will be hunting for gears?
"just pick a number and plug it inIt takes more to get going, which makes more heat in the converter.
