Auto Trans?
Ridgerunner
573
Stillwater Ok
I plan on converting my 4 speed manual trans for a auto trans what will fit a 300 I6?
flareside_thunder
7,812
246
Anything smallblock.....a trans that's not electronically controlled would be the best....less work and no wiring to mess with...the C6 and the AOD are both good trannies...if you want overdrive go AOD.
Ridgerunner
573
Stillwater Ok
The AOD is not as tough but is less parasitic.
The AOD can be built to hold up with moderate horsepower right?
384
how much horsepower are you talking? if its just out a stock 300 a AOD will be fine as long as its taken care of. a C6 is best, but no overdrive.
what are you using the truck for?
Ridgerunner
573
Stillwater Ok
It will have a 351W or a 460 in it after I repaint. Looking for EFI 351W now. I plan to lower it and use it as a DD and street truck.
384
well if ya decide to do it it will look a TON better.... jk.. i have a sweet spot in my heart now for Gen 8's......
I miss the ole 88.......
Fordzilla80
Ranger Lariat
6,372
262
Narnia
I'm cheap LOL.
If you can find someone who knows about the AOD and can tune it right,you'll be fine.
If you get an engine bigger than the 351W,you'll be looking for another transmission because the bell housings will be different.
135
Trinity Tx
