TexasNomad
FTFS Designated DRINKER!
Cool thanks man.
Hahahahha you're an ass.I figured Chris would have posted in this thread by now.![]()
actually its probably jealousy about being able to count higher than twenty.
Jerome,
With a 1988 you should have a C6 automatic transmission. Look on the left side just in front of where the linkage enters the transmission and see if there is an test port plug. If there is you can just screw the sender into this port. Senders are available with different diameters to match your port. Any good quality gauge will work ie Autometer, Isspro, DiPricol. Since you are leaving in a few days go to your local autoparts and get what they have in stock as you wont have time to order one.
I have included a few pictures of a C6 with test ports, there is one the wrench is on and one in front of the wrench as well.
