primetime
sawmill slave
Ya`ll may remember that my F-250 had engine issues a while back. So after calling around and finding out that I could have one for $475 (217,000 miles) or a bunch for $600 with over 100,000 miles, I decided that I was going to put a new one together.
Then I remembered that the yard in town had recently gotten in a 94 F-250 that was packing big block power. So I went and talked to them and they said it ran good and the truck was only scrapped because of a bad brake line . I threw a battery in it fired it up and was rewarded with 114,000 miles, no smoke, and no rattles. Other than the typical 460 manifold leak it was healthy. The price? $350. And well, since I`m a wall to wall engine kinda guy, I bought it.
I wanted to put a Voodoo cam in it and a set of headers, but the budget is tight and I miss my truck, so the manifold bolts are getting fixed, new oil pan gasket and rear main, and that's about it for the moment. Maybe later. Anyways, on to the pictures.
Here`s the truck
Engine porn
My rebuilt big block trans
460 frame mounts on the left, 351 on the right.
What they`ll look like installed.
For the record, I wont do another swap this way. All the brake lines became casualties in the process of getting the driver side mount off, and it was a time consuming PIA between taking off the old ones and going to my buddies and cutting the 460 mounts off of one of his junkers. The price was right (12 pack of Killians for the mounts and a 460/c-6 brain), but the last time I did this I used L&L swap mounts and I personaly think that`s the way to go.
Anyways, I`d hoped to get the mounts bolted up and the manifolds off, but I got bolts that are to long , and I`m doing this outside because the garage is full of truggy, the wind is blowing like a sob, and the fire danger is real high and I`ll need my torches to assist. I`ll keep you updated.
Here`s the truck
Engine porn
